First Build, Need HELP!
Churche
12
I just finished putting together my first computer build and I've come into an issue. I've installed everything correctly to my knowledge and have double checked everything, reseated it all a few times now and the outcome is the same. Whenever I startup I get one long and two short beeps, and nothing else. Nothing will turn on and I was curious on what to do.
Build:
G.SKILL Ripjaws Series 8GB (2 x 4GB)
MSI 970A-G46 AM3+ AMD 970
SAPPHIRE Radeon HD 7870
AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo)
Seagate 1TB
Quicker the better! :)
taking into acount that the HD7870 has a moderated max TDP of 175W, and Vishera FX-6300 95W
you better check your PSU as RAIDMAX is marked as NOT RECOMMENDED psu
A-TOP Technology
Apevia
APEX (SUPERCASE/ALLIED)
Aspire(Turbo Case)
ATADC
Athena Power
ATRIX
Broadway Com Corp
Coolmax
Deer
Diablotek
Dynapower USA
Dynex
EagleTech
FOXCONN
FSP Everest
HEC Orion
Hiper Type-R
Huntkey
I-Star Computer Co. Ltd
In Win
JPAC COMPUTER
Just PC
Kingwin Inc.
Linkworld Electronics
Logisys Computer
MGE
MSI
NMEDIAPC
Norwood Micro/ CompUSA
NorthQ
NZXT
Okia
Powmax
Q-Tec
Raidmax <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Rocketfish
Rosewill
SFC
Shuttle
Skyhawk
Spire Coolers
Star Micro
STARTECH
Thermaltake Purepower NP
Thermaltake Purepower RU
Thermaltake TR2 (and TR2-RX)
TOPOWER TOP
Ultra X-Connect
Ultra X2 >greater than 700 watt
Ultra LSP
Wintech
XION
YoungYear
Zebronics
The 7870 draws 144W max
And this is start up, not load. The only issue with the Raidmax is that it may be a defective unit
Try using only 1 dimm and try out all the slots
Churche
12
Alright I'll swap try using each of the slots and let you know!
