First build need help
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K - $230
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&Tpk=2500k
GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard - $108 (338)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502
Crucial 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model CT2KIT51264BA1339 - $40 (378)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148347
COOLER MASTER Elite 430 RC-430-KWN1 Black Steel / Plastic Computer Case - $40 (418)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
XFX Core Edition...
What is the computer primarily going to be used for.
The motherboard is fine, the HD is fine, you can probably do without the sound card.
Other stuff I will change after you tell me the sorts of things that you will be doing on the computer, most likely.
XFX Core Edition PRO550W (P1-550S-XXB9) 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply - $61 (479)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013&Tpk=xfx%20550w
Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $85 (566)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
XFX HD-695X-ZNFC Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity - $224 (790)
That gets you under $800 for the full system.
I really would have liked to have another $100 to feel good about this because I had to make a lot of sacrifices I really didn't want to make to get it under the budget.
In any event, it should still perform very well. I am just not happy with the hard drive, the case, and it really would have been nice to get an ATX motherboard instead of a micro board.
With $100 more I could have gotten the part I wanted for each of those.
