First Build (need some advice)
VICTORIAESTMEUM
Okay to start off this is my first pc build and what I am looking for is a budget gaming rig. I am leaning towards an AMD Phenom II X4 build. Would it be better to go with the FX 4100 instead? I have not heard very good things about the FX series so I am hesitant about going the FX route. Here is a list of the components I have picked out so far.
Case: CM Haf 912
Mobo: ASUS M4A88T-M
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131657
CPU: AMD Phenom II x4 960T Zosma
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103995
For a powers supply I have picked out a corsair CX500 bundled with two sticks of 4gb Corsair Vengeance. This being my first build, I am confused as to which would be a better setup. Any help/advice would be greatly appreciated.
truegenius
2,686
122
phenom 2 x4 955 is best (in amd) for gaming in budget,
so instead of 960t go for 955
or to get max performance go for phenom 2 x4 980 (little expensive)
fx 4100 is junk for gaming at these price
kinggraves
951
12
Phenom II x4 955BE is best for gaming on a budget.
955BE > 960t > 955
Zosma is fine too if you can't find 955BE, there's no major difference.
K version Llano is also possible depending on the budget and discrete GPU used.
truegenius
2,686
122
black edition does not add performance at stock settings
and it is obvious to go for a be
960t is equalent to 945
and 955 is wining majority of test from 1075t (unlocked 960t will become 1075t) here
www.anandtech.com/bench/Product/88?vs=185
VICTORIAESTMEUM
Wow thanks for all of the replies. I wasnt expecting so much help so soon. It looks like 955BE are in very short supply right now so I might have to to go with the 960T. Since hard drives are so expensive recently, what do people think about the re-certified drives on newegg? Again, thanks for all of the help.
P.S. thanks mousemonkey for moving the thread.
Similar threads
