[SOLVED] First build need some help
Aug 27, 2019
16
Hey guys could you check my list of components for my first build?
My goal is gaming on 1440p
Because i have a asus tuf vg27w qhd monitor. https://pcpartpicker.com/list/6CHYYH
Also how would my airflow be with the 2 redux fans in front as intake and the ml120l in the back as exhaust( also the stock fan as exhaust on top? Or would that be too much?)
suggestions are always welcome!
Looks like a great build, i don't think the 3600 will need that cooler though, Those fans will provide plenty of airflow in that case, which will be enough for the stock cooler
Also if you have the rgb ram, why not go for addressable rgb fans that match your motherboard? have a look on the maunfacturers website for the motherboard, they will have a list of compatible fans there
