First build, no display, red lights
Brammieboy
7
This is my first pc build. The build went smooth and when i turned it on the fans started spinning and the motherboard and gpu activated their rgb-lightning. But i didn't get a video output. I tried different monitors and different connections (HDMI and vga) but nothing seems to work. On the motherboard there are two red lights: "boot" and "gpu led". I don't get any beeps. When i start up the system without the gpu, i do get beeps: 1 long 2 short. Any help?
My system consist of:
MSI b350 PC MATE
gtx 1070
HyperX 2X8GB DDR4 2666 RAM
600 watt power supply
480GB SSD
I tried a cmos reset with the gpu in place, but it didn't change anything. CPU power cable and RAM sticks are properly seated. I also tried with just 1 of the RAM's (in the right slot) but it didn't change anything. Is it maybe possible my ram isn't compatibele?
