First Build. No Display
Possible but first shutdown your system. Reseat the GPU by pulling it out of the PCIE slot the push it back in. This helps ensure a good connection with the PCIE slot connectors. Restart you system to see if it helped.
DVI is plugged into motherboard. Cpu power is plugged in.
DVI is plugged into the wrong place then. Must be plugged into the video card. The motherboard outputs no display with the 1500x.
That worked for a bit. Started installing windows, walked away and came back to a dark screen. VGA light is on now. Could it be that my graphics card is defective? I bought it from amazon in "like new" condition, but it had clearly been opened before.
