Question First Build, No Display
Jul 22, 2023
I just built my first pc and I get no display, everything seems to turn on though. Also a constant orange light shows up on the back of the motherboard. I tried swapping out the GPU for an old one and still nothing, same with the ram. Thanks for any help.
Here are my specs:
CPU: i3-12100F
PSU: EVGA 650W B5
GPU: GTX 1650 super
Motherboard: Gigabyte B660M DS3H
Ram: 16 GB DDR4-3200 CL16
1000
Motherboard has 4 slots for ram, which one's are you populating with the sticks? Slots A2 and B2 are what need populating, makes sure the ram is seated properly. Did you make sure to secure all power connections from the PSU to the motherboard and GPU(assuming the one you have requires supplemental power input)?
You're referring to the part in the picture, with a trace/outline? That's the LED for the audio separation on the motherboard's PCB.
