First build not working have a weird restart loop please help
dimatkachuk2607
22
Hello guys
First of all my setup:
Gpu gtx 960 4gb dual fan (reused from older pc)
Psu seasonic 620 evo (reused)
Motherboard asrock ab350 pro4
Cpu ryzen 5 1600 with amd cooler
Ram 2x8 trident z 3200mhz sticks ddr4
Crucial mx300 525 gb sata 2.5
S340 case
I have not tried anything yet guys so please help me out here I was very careful building and started first with the power supply plugging it in the outlet and touching the case every few minutes for grounding
The probelm right now is the computer boots up all fans running nothing on screen for about 10 15 seconds and restart loop. I think i got everything right i am just no
t sure what rhe problem is
MERGED QUESTION
Question from dimatkachuk2607 : "First buils not working could use some help"
Hi that is the one that says cpu on it and splits to 4 pin headers from 8 right? Both are connected to the atx12v1 connector.
So far ive tried my old ssd and nothing
Ive tried each ram stick in each slot 4 times and nothing
I think its either cpu mobo or ram even though i tested the ram who knows or one of the many cables
I will try reconnecting that cpu cable if thats the one you meant some more help would be great thanks
Sorry for spelling mistakes i am on my phone no computer right now
Sadly i have no other ddr4 sticks i Can try but both of this are on the qvl list and from a reputable company
Are you sure they might be the problem? I tried every comination with them.
Can you even oot without any ram stick?
MERGED QUESTION
If you have too few standoffs it will make no difference in the operation of the machine. But if you've added a standoff where one doesn't belong, it could be shorting out the back of the board. If I were you, I would take it apart and breadboard it.
Set the board on an insulated surface... like the box it came in. Connect just the CPU/cooler, 1 stick of RAM (check your manual to see if a single stick requires a particular slot), gfx card, monitor (to card, not on-board port), PSU, keyboard. No drives or anything else. To start the system, momentarily short the two pins that the power button would connect to. See if you get a display.
