I've been doing my research (like a good boy) and I came up with a build. Overall I would want a 1000$ budget, but I could exceed a little. And then there's the monitor, mouse, keyboard, and OS I gotta buy. But I will worry about that later.
My preferences:
-Prefer Intel build. No sli or crossfire. No raid? Tell me if I should. Looked for parts on Newegg, but necessarily won't buy everything there. Prefer a cool case. No water-cooling.
My concerns:
-When I calculated the total price of my build, I got like $1300, not including the peripherals. So I am looking to cut down the price, while having a really good build. When I was making the build, I tend to look for parts that are "top sellers and best rated" on Newegg. So please give any advices on my build, like cutting down the cost or recommending different parts and etc. This is my first time making a thread here, so I appreciate your help. Thanks.
My build:
1) CPU- Intel Core i5 2500k Sandy Bridge Probably won't change this.
2) Mobo- AsRock z68 Extreme Gen3 Not too confident on motherboards.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
3) RAM- G. Skill Ripjaws Series Is there a better one than this? http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
4) Case- Cooler Master Haf 932 I like this case, even though its a bit pricey...
5) Power Supply- Corsair Professional Series HX750 Is this 140$ PSU really necessarily?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
6) CPU Heatsink- Cooler Master Hyper 212 Plus... I'm okay spending $30 on this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
7) Video Card- GTX 560 Ti I'm kinda confident on this, and kinda not...
8) HDD- Samsung Spinpoint F3 Is this good? Can I get a cheaper one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
9) SDD- Crucial M4 64GB Do I need both sdd and hdd?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441 Or should I not get a HDD, and get a 128GB sdd?
Thanks!
My preferences:
My concerns:
My build:
Thanks!
