first build please help will this work?
chrisod1
will all these parts work? thanks for any advice .
Casecom CM-431 Shiny Black MicroATX Case -
650w Power supply GOLD 12cm 24pin sata model
Crucial 8GB (2x4GB) DDR3 1333Mhz Ballistix Sport Memory Kit CL9 1.5V
Toshiba 500gb 3.5 Int Sata 7200rpm Hdd 395417
SAPPHIRE DUAL-X R9 270 2GB GDDR5 WITH BOOST & OC Dual DVI HDMI DisplayPort PCI-E Graphics Card
Gigabyte GA-78LMT-S2P Socket AM3+ VGA DVI 7.1 Channel HD Audio mATX Motherboard
AMD FX-4130 3.8GHz Socket AM3+ 8MB Cache Retail Boxed Processor
I would agree get the FX-6300 you would be happier with the performance. If your PSU is a off brand consider a good quality PSU from Corsair Seasonic XFX Antec or such. The PSU is really one of the most important components in a PC. It is really the heart of the system and if it goes bad it can take the whole system with it.
Not too sure, but I think ill get a corsair psu any particular 1? so will all this work? I am still getting to grips with everthing involved. also I think I will go with fx6300.
I was going to change and go with Corsair 600W CX Builder Series 80 Plus Bronze PSU is this ok? also any advice on gpu? would like maybe a slightly cheaper alternative, as this is at top of my budget at the min. thanks again
This power supply is ok but not great.
You only really need a 500W power supply.
Here are some units that are better than the CX above:
Antec HCG 520
Seasonic G 550
Seasonic S12ii 520
You could get an Nvidia GTX 650 Ti boost, which is cheaper and close in performance to the R9 270.
This guy is also right, you only need around 500W so those are some good choices.
The nvidia option is preety much the same as the R9 and i do believe it uses less power, so unless you want amd, you may want the GTX.
