I just completed my first build, with some bumps (some solved by suggestions elsewhere here). I seem to have one remaining embarrassing issue: I don't know how to power the DVD drive :-(
The case is an InWin 901, whose instructions are pretty sparse: they assume that you know what all of the plethora of cables are for. The 901 has a sort of hidden compartment for installing a slim ODD, and the instructions show you how to insert it and screw it into place, but not how to connect it. There is a pair of cables that would seem to be for this drive; one is a regular SATA, but the other ends in a weird connector with sort of a plastic shelf and space for four pins but only two, on the left side.
I assume this is obvious to most people, but I simply don't know how to plug this into the PSU (a Corsair CX430). Since every component seems to come with a zillion extra cables for every possibility, I'm surprised that there isn't something that would fit this.
Google wasn't too helpful, as I'm not even sure how to form the question.
Thanks!
Thanks!
