Hi, building pc for the first time this is parts list ignore prices: https://pcpartpicker.com/list/72hXKZ
I live in south Africa so have very limited options
can only spend 10000 rands so like 600 dollars
can only use this site for parts: https://www.evetech.co.za/PC-Components/corsair-power-supply-78.aspx
madmatt30 :
All fine apart from that raidmax psu mate which is dire quality.
MERGED QUESTION Question from Jonty14 : "Are my parts compatible"
Jonty14 :
I know pcpartpicker has a built-in compatibility filter but if you could take some time to just double check and tell me what you think of my parts.
Link: https://pcpartpicker.com/list/YcmPPs
Snipergod87 :
No link?
velocityg4 :
Definitely compatible. Nothing works with nothing better than anything.
manddy123 :
No HDD? If you plan on gaming on that PC with the SSD alone you will run out of space very quickly.
I'd speed up the ram a bit. For $14 more you can get 3000MHz with will be much better for that Ryzen CPU.
velocityg4 :
Yes, they all work together. For the budget you could get a faster CPU model.
HI building first build gaming pc
Link: https://pcpartpicker.com/list/RpYDtJ
Ignore the prices
Have to use these sites only: https://www.evetech.co.za/ and https://computermania.co.za/product-category/components/
Wondering about the psu?
thanks
MERGED QUESTION Question from Jonty14 : "What psu for budget ryzen"
Jonty14 :
First budget gaming build wondering what psu cant get CX450 cause not in stock where i live
thinking EVGA 500w 80+
parts list: https://pcpartpicker.com/list/PcBgVY
Will it explode?
smorizio :
https://pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze
better unit
4745454b :
What GPU? Where do you live?
MERGED QUESTION Question from jonty04 : "Power supply for budget gaming build"
jonty04 :
I'm trying to decide which power supply to get for my first budget gaming pc build love your thoughts thanks
Antec 500p 500w 80+ or Raidmax XT Series 500W Power Supply
Parts list: https://pcpartpicker.com/list/RwvXKZ
swissgoch :
It preference really(and of course your build), If you are dead set on either on of these power supplies did you do some research and compare?
