First build what do you guys think about it?
VoeY789
Commendable
Jul 25, 2016
4
Hello I am planning on buying parts for my very first custom PC this week and I came up with this build, what do you think about it?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (€212.50)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard (€96.89)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory (€107.29)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive (€95.90)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive (Purchased For €0.00)
Video Card: Zotac - GeForce GTX 1070 8GB AMP! Edition Video Card (€444.90)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case (€60.49)
Power Supply: Corsair - Builder 500W 80+ Bronze Certified ATX Power Supply (€59.90)
Total: 1077.87 €
I`ll be buying parts in Lithuania from this website http://www.skytech.lt/. PC will be mainly used for gaming and browsing web but I will learn some codding in the future. For now I`m going for 1080p 60FPS high/ultra but in the future i will buy 144hz monitor which is why im going for GTX 1070. My max budget is 1100 €. Im planning on buying extra 8gb RAM in the future as well.
Could I slightly overlock my RAM/GPU/CPU? I Havent ever done that but I heard it's worth doing for some extra performance. Are parts compatible? I did my best checking but Im still not 100% sure. Thanks for taking your time to read this.
i vouch for your build, it's pretty awesome and well balanced
it's all compatible don't worry
OC guide:
CPU: motherboard should already come with some OC profile, u can just use that for ez OC
GPU: Nvidia already comes with GPU Boost, which will boost your clock according to the situation
RAM: same as CPU, however, higher than 2677 would require some manual OC, so u should do some research on that :)
the only thing u should change though, is your PSU
for overclocking, you should go with a tier 1 / 2 PSU:
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
i think this one is enough:
http://www.skytech.lt/cp9020133eu-corsair-power-supply-tx550m-550w-plus-gold-semimodular-120mm-p-343851.html
or this...
OC guide:
or this
http://www.skytech.lt/210gq0650v2-psu-evga-650w-plus-gold-full-modular-p-343136.html
