First build, will this work?
Demonfighter66
Commendable
Sep 7, 2016
9
Hi, will these components work well together? It is for 720p gaming cause I have 720p monitor with vga, which I'm fine with. I have some room to improve this build, maybe make it more stable somehow? Because I want it to last some years. Components list: Zalman ZM-T4 Mini Tower ohne Netzteil
Intel Core i3 6100 2x 3.70GHz So.1151 BOX
8GB Crucial CT2K4G4DFS8213 DDR4-2133
MSI H110M PRO-D Intel H110 So.1151 Dual
1000GB WD Blue WD10EZEX 64MB 3.5"
120GB ADATA Premier SP550 2.5"
430 Watt EVGA 100-W1-0430-KR Non-Modular
2048MB MSI GeForce GTX 750 Ti Low Profile
Edimax WL-USB EW-7811Un (150MBit) mini
Thanks In advance!
There is a quality XFX 450W unit on sale right now. for that price (39€), insane!
if you want a modular one, the Seasonic M12II (60€) is really good for your needs
what's your budget?
that build will work, however I'd go for a better PSU
a Seasonic S12II / XFX (not the XT series) / Corsair CXm would do better at minimum additional cost if any
also what are you paying for the 750Ti because there might be more potent cards at the same price available to you
and lastly: from which country are you buying?
Wow fast answer, thank you! Ah yeah wasn't too sure about the psu. I'm currently living in France, but thinking of buying from the german site:"mindfactory.de". Everything seems more expensive in France. The 750 ti is 109 euros. My budget is around 550 euros but delivery costs seem 40 euros, so 510 left. i chose the 750 ti, since I got vga monitor, and not too sure about rx 460 with some sort of adapter.
Added it, thank you so much. Everything else seems fine and will fit? Like the combination of mobo with psu will be able to connect the hdd+ssd? And I took the xfx one, since I need non modular, since I need all cables. Got nothing haha.
