I just built my first computer, at least most of the way. I've put together the motherboard, CPU/fan, 2 sticks of memory, HDD, PSU, and hooked everything up according to the MoBo manual.
The motherboard is receiving power, as indicated by the onboard LED. I also know the IPMI (whatever that is) is functioning properly because that LED is flashing.
However, when I press the power button, nothing happens beyond that. The fan doesn't spin, no noises are made, nothing. To make sure it wasn't just the power button, I removed the power button connector, as well as all the reset and LED connectors on that strip. I then used a screwdriver to connect the power button pins, and still got no results.
Any ideas as to what might be the problem? I know this isn't the easiest thing to troubleshoot. I can share any information needed.
