F felrandy Honorable Dec 18, 2013 4 0 10,510 Dec 18, 2013 #1 Hi, i want to ask for your opinion on this build I've found and modified. My budget is around $1,000 and only those parts are needed. http://pcpartpicker.com/p/2msEO
Solution siddharthmukul007 Dec 18, 2013 your mobo is fine....better ones are a little more expensive.take a look though: http://pcpartpicker.com/part/asrock-motherboard-990fxextreme4 http://pcpartpicker.com/part/gigabyte-motherboard-ga990fxaud5 http://pcpartpicker.com/part/asus-motherboard-sabertooth990fxr20
siddharthmukul007 Honorable Sep 16, 2012 2,356 0 12,460 Dec 18, 2013 #2 where is your system specs??? Upvote 0 Downvote
F felrandy Honorable Dec 18, 2013 4 0 10,510 Dec 18, 2013 #3 sorry, i though i pasted the link, guess not 😛 Upvote 0 Downvote
siddharthmukul007 Honorable Sep 16, 2012 2,356 0 12,460 Dec 18, 2013 #4 psu is a bit over priced....you can settle for this: http://pcpartpicker.com/part/seasonic-power-supply-ssr650rm and instead get a better cpu cooler may be the corsair h80i Upvote 0 Downvote
F felrandy Honorable Dec 18, 2013 4 0 10,510 Dec 18, 2013 #5 thx for the advice, will change it. The graphic card is my main concern, is it compatible and good for the MOBO? or are there better at around that price? Upvote 0 Downvote
siddharthmukul007 Honorable Sep 16, 2012 2,356 0 12,460 Dec 18, 2013 Solution #6 your mobo is fine....better ones are a little more expensive.take a look though: http://pcpartpicker.com/part/asrock-motherboard-990fxextreme4 http://pcpartpicker.com/part/gigabyte-motherboard-ga990fxaud5 http://pcpartpicker.com/part/asus-motherboard-sabertooth990fxr20 Upvote 0 Downvote Solution
F felrandy Honorable Dec 18, 2013 4 0 10,510 Dec 18, 2013 #7 I'll stick with the ones i have, thx so much for you help. Will buy the pc in a few hour. Upvote 0 Downvote
siddharthmukul007 Honorable Sep 16, 2012 2,356 0 12,460 Dec 18, 2013 #8 all the best and good luck Upvote 0 Downvote
