So, I am looking to get back into PC gaming after a long absence and want to make my first PC build to do so. I am looking to try my hand at OCing as well, first with CPU, and then go on from there. Here is just an overview of parts being considered.
CPU - Intel i5 3570k http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard - MSI Z77A-GD65 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130643
GPU - 2x GeForce GTX 670: Gigabyte N670OC-2GD http://www.newegg.com/Product/Product.aspx?Item=N82E16814125423&Tpk=gigabyte%20670
Memory - G.SKILL Ares Series 8GB 1600 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231548
SSD - 120gb Pyro SE http://www.newegg.com/Product/Product.aspx?Item=20-220-624
HHD - For now, stock 160gb drive in my home computer
Heatsink - CORSAIR H100 Extreme Performance Liquid CPU Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835181017
PSU - Thermaltake Toughpower Grand TPG-1050M 1050W http://www.newegg.com/Product/Product.aspx?Item=N82E16817153144
Case - NZXT Phantom 410 http://www.newegg.com/Product/Product.aspx?Item=N82E16811146087
DVD Drive - Just pulling from current home computer
So, basically, I have no true budget, I just plan on buying items over a period of time. I have already gotten the 120gb Pyro SE for 100 and the G.Skill Ares 8gb for 47. Then, after that, I smartened up and realized I should be consulting for some help. So, I have a couple questions about my build.
Should I continue with 2 GTX 670s? From what I understand, they have better stock performance than the 7970, but the 7970 OCs better. So in a few years when I may need to OC these cards, would it be best if I have two 7970s or is it not worth it at this point to worry about it and stick with the 670s? (To note, I have found 7970s now at the same price as the 670.)
As well, I would hope everything would fit in a mid-tower, but should I get a full tower? My choice for CPU seems to be pretty frequently recommended for OCing, but I had more trouble deciding on a board. Should I spend more to upgrade from my current choice? Also, any other suggestions people have I would love to take. Thank you.
