First built i5-2500k with gtx 560 ti
Antares16M26
64
this is going to be my first built im backing off of my laptop since they are impossible to upgrade and i prefer desktops i have a desktop in my living room but its too old to upgrade i had it since 2005. need tips if this is a good build if its compatible with all the parts and if im missing anithing else or if i can drop the price a bit.not sure about the graphics card is there a better brand/reliable than PNY?thinking about the twin frozr II.this going to be mostly for gaming getting ready for battlefield 3,skyrim,rage, and diablo 3.
Rosewill ARMOR Gaming ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147047
ASRock Fatal1ty P67 PROFESSIONAL (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157240
PNY VCGGTX560TXPB-OC2-S GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133380
MSI N560GTX-Ti Twin Frozr II GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127594
OCZ OCZ750FTY 750W ATX12V / EPS12V SLI Ready 80 PLUS BRONZE Certified Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341041
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231468
Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136792
SAMSUNG B2430H Glossy Black 24" 5ms Full HD 1080P Widescreen LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001388
LG DVD Burner Black SATA Model GH24NS70 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136236
Microsoft Windows 7 Home Premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116716
Rosewill - Pellucid HD Series High Speed HDMI® cable (6 FEET)
http://www.newegg.com/Product/Product.aspx?Item=N82E16882021128
Antares16M26
64
Yeah I noticed it was out of stock It will come back on stock; and for the SSD I'll wait for it to drop in price not interested in expensive 80gb drives yet I'll wait till they go to a nice cheap 500gb then I'll think about getting a SSD.
