Hi, as the title suggests. I could use some help.
My build:
CM Storm Trooper
Asus Z87-Plus
Intel Core i7 4770k
EVGA GTX 780 SC ACX
Corsair Vengeance Pro 2400Mhz (2x8)
Seasonic Platinum Series 1000w
Samsung 840 Pro 512GB
Corsair h110 with Noctua fans
BenQ XL2411t
I will not use a HDD and I will use an external optical drive to install the OS.
My problem is that I just built this pc, but my monitor doesn't get a signal. I tried another monitor with a VGA connection, but that didn't work either.
I double checked if everything was connected, I only have 2 connectors unplugged which say WST on them. It's supposedly from some LED, but I'm not entirely sure. Everything else though, is connected.
I was reading other people's topics who had the same problem as me. I tried some of the solutions posted by some people, like booting the system with only 1 memory, but it didn't work. I made sure to have the memory cards properly connected. But still no result.
Some people mentioned that your motherboard will make a beeping sound to indicate it's working when you turn it on. But mine doesn't make that sound, but I'm not sure if every motherboard does that. I hope mine doesn't...
There are only 2 conclusions I'm able to draw here. One is that I damaged my motherboard somehow. The other is that I screwed up on the connectors.
Everything seems to run though when they receive power from my PSU, so the latter seems unlikely.
Even so, I hope someone can show me the light here, because I'm sitting in utter darkness right now.
My build:
CM Storm Trooper
Asus Z87-Plus
Intel Core i7 4770k
EVGA GTX 780 SC ACX
BenQ XL2411t
