First computer build for after effects and rendering
Jul 30, 2018
8
I am going to build my first desktop with a budget around €2000
I made my list on a website called tweakers and tried to remake it on pcpartpicker .
the only thing I wasn't able to find was the PSU which is a pretty important part.
Could I get some feedback about my build and if it is all compatible?
CPU: Intel Core i7-7820X
Motherboard: Gigabyte X299 UD4 (rev 1.0)
Memory:G.Skill Sniper X F4-2400C17Q-64GSXF
Storage:Samsung 960 EVO 250GB
Video Card: Gigabyte GeForce GTX 1080 WINDFORCE OC 8G
Case: Fractal Design Define C TG
PSU: Inter-Tech Argus RGB-750W CM
Monitor: LG 29WK500 Zwart
Operating System: Microsoft - Windows 10 Home OEM 64-bit
I would choose a power supply with lots of posative reviews like the Seasonic M12II Evo 620W. There are no reviews of the Inter-Tech Argus RGB-750W CM anywhere.
https://tweakers.net/categorie/664/voedingen/
Alright, thank you! what amount of watt should you recommend for the PSU? pcpartpicker tells me the build needs 446W.
Also with an eye on the future that I won't need to replace it too quickly.
The 1080 video card is the only part in your system that uses a lot of power and Nvidia recommends a 500W PSU as the minimum, so 600W should be plenty.
ok i'll go for the Seasonic Focus Plus 650 Gold
thanks for the info
