I am having a system built, I'm just a little less knowledgeable enough to build my own, so this is as close as I want to get. I already have a win 7 license and that's the OS I want, so that isn't necessary. Can anyone tell me if this build is ok? I did some basic checking and my budget was less than 1k, but I'm paying a bit over that just because there are some things I won't cheap out on (low wattage for PS, videocard specs, etc.)
Intel Core i5-3570 Ivy Bridge 3.4GHz (3.8GHz Turbo) Quad Core 6000K
Coolermaster Hyper101, Vertical, 2 Copper Heat Pipes, Extra Quiet CPU fan
MSI Z77A-G41, Onboard Video, HDMI, X-Fire, USB 3.0, SATA3, GB LAN
16GB (2x8GB) PC10600 DDR3 1333 Dual Channel
GeForce GTX 660 Ti 2GB PCI EXpress 16X Quad l head, HDMI
1000.0 GB Western Digital Green SATA3 6GB/s 64m cache
Sound Blaster Audigy SE 7.1
Ethernet network adapter (onboard)
Apevia X-Dreamer 3 Pink front USB, eSATA, LCD temp. display
Apevia 700W Extra Quiet Power Supply SLI & X-fire ready
Am I missing anything I should be getting? Is anything not compatible? Yes, it's pink. I'm a girl gamer who does a few graphic things and internet stuff mostly, so hopefully this will do it. Thanks in advance!
