First Ever Build Help
Damwuse
Commendable
Jul 26, 2016
43
Hello pc master race, payday is around the corner and i am considering building my first ever gaming pc! My plan is to be playing the latest AAA titles at 1080p at 60+ fps on ultra settings (Fallout 4, BF1, withcher 3, no man's sky etc) . In terms of budget, i'm looking at around £1500 max. I have been researching parts for around a month now and have chosen the following components: http://uk.pcpartpicker.com/list/cMC8M8 i aim to be building the pc in a week or two, any tips and advice on how i could improve the build would be really appreciated, cheers :)
looks good.
but you might wanna consider going for a GTX1070, the 980Ti is last gen and they're basically on par and cost almost the same
some say MSI boards aren't the greatest boards, an Asus/Gigabyte in the same price range should do
personally I find the window quality of the case not that appealing and would go with the no-window-version, but that just comes down to personal taste
looks good.
Well, as Isokolon said, might as well go for a GTX 1070 if anything because of the much better VR performance. But other than that...
Perfect, thanks a bunch! :)
