This build is going to cost me around the £l,300 mark, so I want to make sure that the build is going to work before I start spending my money. I know that the power supply is a bit over kill, but it should give me the ability to upgrade to SLI if I ever need any more performance. I will most likely upgrade to a 1440p monitor in a few month from the current 1080p one. I don't plan on overclocking the GPU much if any, but I do plan to do a bit of on overclock to the CPU. Please if you would be kind enough can you tell me if this build below will work?
CPU: i7 4790k
GPU: EVGA GTX 980Ti FTW ACX 2.0+
Motherboard: MSI Z97 Gaming 5
RAM: 8GB HyperX Fury DDR3 1866MHz
PSU: Corsair RM1000X 1000 W ATX/EPS Fully Modular
SSD: Samsung 840 EVO 250GB 2.5 Inch
CPU Cooler: Cooler Master Hyper 212 Evo
Monitor: BenQ GL2450HM 24 inch
Case: Fractal Design Define R5 Pearl Window Side Panel - Black
CPU: i7 4790k
