I'm using an Asus Swift PG279 1440p monitor with a GTX 1080 Ti through a display port, also running Windows 10 Pro 64-bit, Ryzen 7 1800X and 32 GB RAM. FPS in games bounce from 60-140 even with very low settings, CPU and GPU monitors don't show any bottlenecks (both are under 40% during heavy explosive gameplay) but maybe I'm missing something. I have tried turning off G-Sync and Vsync and just setting the monitor to a flat 144Hz but it looks and acts the exact same.
In Nvidia Control Panel I've enabled the performance option for power management, and set performance mode for my main display only. Both global and 3D settings for specific games are set to G-Sync, and I've tried just leaving vertical sync off to run the game uncapped, but still bouncing from 60-140. Why would it not use more video card to pull higher fps if the game options are set to uncapped? I don't even know if this is specifically a monitor problem, but hopefully somebody can give me insight. Thank you very much for your time.
