First gaming build help!
Joe Vail
4
With help from a friend, this is the build we have came up with. I am looking to use the pc for gaming and general use. Any comments, advice, improvements would be greatly appreciated!
Thankyou :)
CPU -
Intel Core i5-4570 3.2GHz Quad-Core Processor
Motherboard -
ASRock H81M-HDS Micro ATX LGA1150 Motherboard
Memory -
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory
Storage -
Samsung 840 EVO 120GB 2.5" Solid State Disk
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card -
Asus GeForce GTX 760 2GB Video Card
Case -
Inwin MANA137 (Black) ATX Mid Tower Case
Power Supply -
Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive -
Lite-On iHAS124-04 DVD/CD Writer
Operating System -
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Your setup seems alright. No need to switch to FX8350 in my eyes but you might need a better PSU. 600W atleast I think. Maybe an Antec High 620W?
Still dont You Think R9 280x will give him alot of difference in graphics ?
All the components are fine and compatible. I would suggest you not to go with CX 500W PSU, its not that good. You can go with HX or TX series better than CX series. Or this one :
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($82.99 @ NCIX US)
Total: $82.99
(Generated by PCPartPicker 2013-12-18 10:33 EST-0500)
And if you have the budget then go with GTX 770.
Your build is perfectly fine, there is NO need for aftermarket cooling on a non K processor. It won't run hot assuming you have decent ventilation. You can go the AMD route if you want but this build should play any game that exists and do so rather well.
Ofcourse the R9 280x would be better, but he might be on a limited budget. It's not necessarry to switch his processor and gpu as it will run games just fine. That's what I meant.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: ASRock Z87 Extreme4 ATX LGA1150 Motherboard
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Sapphire Radeon R9 280X 3GB Video Card
Case: Thermaltake VL80001W2Z ATX Mid Tower Case
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply
Optical Drive: Lite-On iHDS118-04 DVD/CD Drive
OS: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
Total: £789.78
http://
If you are not looking to overclock, save yourself the cash and get a cheaper motherboard and a non k i5 processor and ditch the cooler. Otherwise, this pretty much fits your budget
Thanks very much!
No problem, remember if you found a solution that helped select it as the best solution to mark this thread solved
