Hi All,
I have been trawling and reading various threads for 2 months as I plan my first PC gaming build. I am hoping you will be able to advise and help me before I jump into this - its much appreciated.
Key considerations:
CPU:
i7 4770K (I have heard that for gaming i5 is sufficient but I have some budget). Might overclock it when i find out how. (Are there programs with the motherboards that can do this?)
Graphic Card:
Need your help on this one
- GIGABYTE WINDFORCE GTX 780, ASUS VGA GTX780-3GD5 or the 770 4GB card or R9 290X 4G DDR5
Impressed with the performance reviews on the R9 290X but worried about sound and heat would drive me nuts - but I have heard that when MSI/Sapphire/ASUS re-build them (?) they could have reduced noise..? The Price of GTX 780's might drop - maybe better going with them? 3GB vs 4GB? I have no loyalties with either card.
Drives:
I have another laptop to store music and documents. So was thinking of ONLY getting a Samsung 250 GB SSD and not bother with a Hard drive? Thoughts on this, is it advisable?
CPU Cooler:
This section is a Big headache for me
, with noise as the main concern. I cant make up my mind between Dark Rock2; Corsair Hydro100i, NoctuaNH-14, Hyper212 EVO, Phantecks PH. I have read on some reviews that the Corair Hydro 100i does make plenty of noise along with the Hyper212 EVO. Please help on this one...
Cases / Tower:
Love the look of R4 Fractal Design and the Bitfenix Cases - Fractal has good sound suppression I believe..I will also be buying 4 Noctua fans to replace the case fans, Ive read this helps.
Motherboard:
Most good things I read were around ASUS boards. Z87 Plus or X79 deluxe, or SaberTooth z87, ASrock Extreme. Asus Hero seemed a little pricey. What you reckon?
Power:
Seasonic x650W is meant to be fairly quiet and fan only operates when it gets warm. Also the Corsair HX850 seems good for audio.
Monitors:
I have read some good things about ASUS monitors but I am also a big fan on SAMSUNG screens. Any recommendations??. Size wise, 23 inches is more than enough. I have ready about refresh rates at 144hz, etc. But not 100% sure on what i need. I'm not a pro-gamer but appreciate landscape beauty like you see in Skyrim, Oblivion, - etc.
Many thanks!!!
Key considerations:
Budget: GBP 1,900 (USD 3200)
Probably will overclock when I learn how to, within a couple months of purchase
Very important to have a quiet running system - dont like fan noise
Will only be playing off 1 monitor only (23 inch)
Parts will be bought in 3 weeks
CPU:
Graphic Card:
Drives:
CPU Cooler:
Cases / Tower:
Motherboard:
Power:
Monitors:
Many thanks!!!
