First Gaming PC Build Advice
Not sure, what kind of games are you looking forward to play, and what settings will you want to play on, if you don't mind graphics that much, I would say that your computer is "OK" for Medium-High settings depending on which game are you going for.. but if you are going straight to heavy gaming in which both are CPU or GPU intensive and have a little bit more to spare, I would pick a I5 7400 or any I5 at least, a I3 Dual Core for heavy gaming won't be much beneficial. As for the GPU I would definetely pick a GTX 1070. As for the PSU, I advise you to pick a 550W if you are planning on upgrading your rig in the future.
But that will all depend on your budget as well.
Cheers.
Cheers.
