Hi all, I am about to build my first PC and I would like if someone could judge the parts I've picked out and suggest better parts or things to swap out if I need to.
I plan to use it primarily as a gaming rig, for games such as Fallout 4, Just Cause 3, a few COD games and other FPS's, etc.
Here is my build:
>CPU- AMD 6300 BE
>GPU- Gigabyte G1 Gaming Radeon R9 380 4gb
>RAM- 8gb (4x2) Kingston Hyper X Fury 1866
>MOBO- ASRock mATX am3+ 970m PRO3
>PSU- XFX TS Series 650 Watt 80+ Gold
>Hard Drive- WD Blue 7200k 1TB
Those are the main parts, already have a case and a few case fans as well. Does this look good, and is there anything I should change to better suit my needs? Thank you in advance for the help!
Here is my build:
>CPU- AMD 6300 BE
