First Gaming Pc Build; Compatibility; Need Advice
RaymondC_THR33
I plan on ordering these parts, along with their required wiring and whatever else I need. Before ordering I'd like some confirmation of the compatibility of these components. If you have any advice of what I will need to change, it would be great if you could share that.
Other than a couple of Sata cables and the obvious mouse, keyboard, and monitor, what other components/wiring do I need for sure?
I am fairly inexperienced with Pc building so any advice is greatly appreciated. My lack of knowledge lies in what materials I need to do this successfully. I know for sure that I am fully capable of putting it together.
Below is a link that will direct you to the list of parts that I found and plan on ordering.
http://pcpartpicker.com/p/CxMJWZ
Sorry for the long description. :\
I would get a 2x4GB kit, get rid of the cooler since you can't overclock, and since you want to game I would downgrade to an i3 and get a better GPU maybe a 960 if you can afford it
