First [Gaming] PC Build? Help required!
Dovahkitty
94
I'm making a budget gaming PC- these are the parts I have in mind- can you think of any better ones, or are the ones I've selected good already?
http://uk.pcpartpicker.com/p/2mVYe
I'd be using it for gaming, on a 1080p monitor. I'd mainly be playing games like The Elder Scrolls V: Skyrim- with lots of mods [would it be able to handle it?], Battlefield 3 and 4. Should I set it up as a PC, or plug it into my TV [PROS- NICER SCREEN, CONS- CAN'T PLAY MOST OF MY GAMES BECAUSE THEY ARE NOT CONTROLLER SUPPORTED]?
If I was to set it up as a PC, the monitor I'd be using is the Acer S220HQLBrbd 21.5" 1080p one- also any good gaming keyboards on a budget? I want to keep the entire build under £800- right now, it comes to about £670, not counting the monitor, and peripherals.
Many thanks for all your help,
Dovahkitty.
Alright, I've taken out the original CPU & Motherboard and replaced it with the ones you specified.
I add the list for you, you can choose the vendor to get the parts. Also if you want you can get the i5 K version+ Z87 MB too, and I think the price should be in your budget.
PCPartPicker part list: http://uk.pcpartpicker.com/p/2mVDY
Price breakdown by merchant: http://uk.pcpartpicker.com/p/2mVDY/by_merchant/
Benchmarks: http://uk.pcpartpicker.com/p/2mVDY/benchmarks/
CPU: Intel Core i5-4430 3.0GHz Quad-Core Processor (£133.65 @ Amazon UK)
Motherboard: MSI B85M-G43 Micro ATX LGA1150 Motherboard (£53.54 @ Amazon UK)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory (£59.69 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.97 @ Amazon UK)
Video Card: XFX Radeon HD 7870 2GB Video Card (£137.74 @ Scan.co.uk)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case (£31.49 @ Ebuyer)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (£48.99 @ Amazon UK)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£13.80 @ Amazon UK)
Operating System: Microsoft Windows 8.1 - OEM (64-bit) (£87.66 @ Amazon UK)
Total: £606.53
(Generated by PCPartPicker 2013-12-19 22:03 GMT+0000)
Tweaked setup accordingly. Now, with that out of the way, what kind of performance are we looking at with these games [on a 1080p monitor]? Just rough estimates.
Ideally at least 30fps on each... :/ I know it's a lot to ask on so tight a budget.
Skyrim without mods, on ultra
Skyrim- with mods, 2K Textures and an ENB [performance version]
Minecraft
Battlefield 3
Far Cry 3
