[SOLVED] First Gaming PC Build. Micro ATX/Mini Itx - £1200 budget.
Jun 2, 2020
Hi everyone
I'm looking to build a gaming PC for £1200 max. It has to be either a Micro ATX or Mini ITX form factor and the budget doesn't include the peripherals or OS.
One particular caveat with the potential build:
  1. I will be upgrading the PC once the new 3080/3080Ti come out. The older parts will then be used for another less powerful build for my partner. So if possible I'd like everything to be compatible for the upcoming 3080/3080 Ti. I have a 4k monitor but will be buying a 1440p 144hz monitor at some point to use instead
Any help to this would be greatly appreciated!
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor (£278.39 @ Amazon UK)
Motherboard: ASRock X570M Pro4 Micro ATX AM4 Motherboard (£184.91 @ More Computers)
Memory: Team T-FORCE DARK Z 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory (£74.09 @ Amazon UK)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive (£114.44 @ Amazon UK)
Video Card: EVGA GeForce RTX 2060 SUPER 8 GB SC ULTRA GAMING Video Card (£389.99 @ Amazon UK)
Case: Fractal Design Define Mini C MicroATX Mid Tower Case (£69.98 @ Amazon UK)
Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply (£79.98 @ Amazon UK)
Total: £1191.78
Generated by PCPartPicker 2020-06-02 16:52 BST+0100
A little over, but here is an ITX to consider.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor (£158.99 @ Amazon UK)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard (£225.99 @ Amazon UK)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3866 CL18 Memory (£91.48 @ Ebuyer)
Storage: ADATA XPG SX6000 1 TB M.2-2280 NVME Solid State Drive (£103.52 @ Amazon UK)
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB KO GAMING Video Card (£495.46 @ Scan.co.uk)
Case: Fractal Design Define Nano S Mini ITX Desktop Case (£62.98 @ Amazon UK)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply (£69.98 @ Currys PC World Business)
Total: £1208.40
Generated by PCPartPicker 2020-06-02 17:07 BST+0100
