First Gaming pc help!
viperfuzz
48
Hello,
I've just made my first pc on PLE computers and to me it looks decent, I will be ordering around Christmas, aim to spend $1600, but with monitor and Keyboard i made one at $1900.
Im curious to see if its fast, high fps and will play general games such as Dota 2, Csgo, Saints row 4 etc.
Are the parts compatible?
Should i upgrade or downgrade anything?
Feel free to just scream at my for my stupidity (i have no clue at all with pc's).
NZXT Phantom 820 White Full Tower Case w/Side Panel Window
Intel Core i5 4670K Haswell 3.4GHz 6MB Retail Box
eVGA GeForce GTX770 SC ACX Cooler 2GB GDDR5 2xDVI HDMI DisplayPort
Seagate Barracuda ST1000DM003 3.5" 1TB 64MB 7200RPM HDD
Samsung 840 EVO Series 2.5" 7mm 120GB SSD
Antec TruePower Classic 750W Power Supply
G.Skill 8GB Kit (2x4GB) DDR3 Trident X C10 2400MHZ
Asus H87-PRO LGA1150 ATX Motherboard
Asus VS248H 24" Full HD WS 2MS LED Monitor
Razer BlackWidow 2013 Ultimate (MX Blue) Mechanical Keyboard.
Thanks,
Stephen :)
hey Stephen! First of all you have a good build, but compatibility may be an issue if you don't have enough PCI slots. I recommend you go to http//:www.pcpartpicker.com and find your parts on there, it will help you make everything cheaper where possible and allow you to see compatibility! Your parts are amazing though individually, so congrats on doing so well your first time! Allow me to show my build which is $1000 dollars cheaper (I'm from GB so it might vary) but also the exact same performance!
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor (£146.52 @ Amazon UK)
CPU Cooler: Xigmatek EP-CD903 61.2 CFM Sleeve Bearing CPU Cooler (£16.24 @ Amazon UK)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard (£66.88 @ Amazon...
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard (£66.88 @ Amazon UK)
Memory: Corsair Vengeance LP 8GB (2 x 4GB) DDR3-2133 Memory (£53.49 @ Amazon UK)
Storage: Western Digital RE3 1TB 3.5" 7200RPM Internal Hard Drive (£37.00 @ Amazon UK)
Video Card: Asus GeForce GTX 650 2GB Video Card (£89.98 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter (£25.98 @ Amazon UK)
Case: Corsair 200R ATX Mid Tower Case (£47.98 @ Amazon UK)
Case Fan: Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm Fan (£5.97 @ Amazon UK)
Power Supply: XFX 850W 80+ Bronze Certified ATX Power Supply (£79.99 @ Amazon UK)
Optical Drive: LG GH24NS95 DVD/CD Writer (£17.35 @ Amazon UK)
Total: £593.35
I would change your RAM to Corsair, specifically corsair Vengeance, as Corsair is the best Hardware build for RAM and cooling.
Thanks for the response, ill build it on there and see, thanks!
No problem, It doesn't seem incompatible though. I would recommend changing the motherboard to Gigabyte though, cheaper and just as good. Yours should last 3-4 years and also *POTENTIALLY* play all games.
