First gaming PC help?
jason1297
104
I'm building my first gaming pc and so far I have the case (corsair spec m2).
My budget (not including monitor and Windows) is £5-600, and I'm thinking of getting a Msi r9 380 for a gpu.
Which is the best CPU to pair with this in this budget?
Also, which motherboard will be most suitable? (I also want pci-e wifi).
My plan is to play games like skyrim and gta v at decent rate.
Considering you have a 600 pound budget, you can get much more than a decent framerate at 1080p than you think! 😀
What settings do you plan to run these games at?
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor (£168.99 @ Amazon UK)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard (£49.99 @ Novatech)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory (£34.98 @ Ebuyer)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£67.98 @ Ebuyer)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.98 @ Ebuyer)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card (£159.98 @ Novatech)
Case: Corsair Carbide SPEC-M2 MicroATX Mid Tower Case (Purchased For £0.00)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply (£59.99 @ Amazon UK)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter (£29.10 @ Amazon UK)
Total: £608.99
Generated by PCPartPicker 2016-03-17 22:53 GMT+0000
Motherboard: MSI H170 Gaming M3 ATX LGA1151 Motherboard (£88.99 @ More Computers)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory (£29.99 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£40.93 @ Amazon UK)
Video Card: Asus Radeon R9 380 2GB Video Card (£158.99 @ Ebuyer)
Case: BitFenix Neos Black ATX Mid Tower Case (£32.99 @ Novatech)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply (£74.99 @ Amazon UK)
Total: £595.87
Generated by PCPartPicker 2016-03-17 22:54 GMT+0000
Pretty decent build, but you don't want to get seagate HDDs or skimp on power supplies. You will spend more money on electricity in 6 months than you would spend upgrading to a gold efficiency rating.
More powerful GPU at the cost of an SSD, but you should be fine with the caviar blue. If you really want an SSD you can swap out the 380x for a regular 380 and grab an 850 evo.
PCPartPicker part list: http://uk.pcpartpicker.com/p/ttfFFT
Price breakdown by merchant: http://uk.pcpartpicker.com/p/ttfFFT/by_merchant/
Motherboard: ASRock H170 Pro4S ATX LGA1151 Motherboard (£83.53 @ More Computers)
Video Card: PowerColor Radeon R9 380X 4GB PCS+ Myst. Edition Video Card (£208.98 @ Ebuyer)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter (£12.98 @ Novatech)
Total: £620.39
Generated by PCPartPicker 2016-03-17 23:38 GMT+0000
Its there for options. Given the games OP is playing, he'd fit one maybe two of those onto the SSD before he'd have to use the HDD anyway. better to spend a little extra on a GPU for better framerate than an SSD which will prob only store 100gb of games.
OP can always upgrade in the future and add an SSD if he so desires. There for options rather than posting the same build as other people :)
Also don't say 'My build is better than youuurs' over a forum designed to help people.
Its not a competition, and if you think it is that's a pretty immature way to view things.
Two options is better than one.
