First gaming rig and I need input!
LonelyNerd
4
Hello! I am looking into building my first gaming PC. I need the money but first I am looking for an estimated price of it in the long run.
Specs:
http://pcpartpicker.com/p/VPNThM
I have a few questions about the parts:
1) Are they all compatible? It says they are, but want to be %100 sure.
2) Are they all good components? Do they function well, and if not are there any other options that are better for a similar price? I wasn't sure about my GPU and my CPU.
3) I want Windows 10, but it cost more to get, so I went for the cheaper Windows 8.1 and then thinking about doing the upgrade afterwards. Is this a good idea? I have Windows 10 on my laptop is there a way to get it for free on this?
4) Do I need to get case fans? If so any ideas on some cheap, quiet, good quality ones?
5) I already have a mouse and monitor.
Thanks in advance for any support you can give me! I am a young teen with about $70 (I better get working for some money) so I really want this to work without any problems!
Hi.
Here's what we do at school http://www.tomshardware.com/forum/id-2625445/build-log-consolidated-middle-school-builds.html
You don't need the thermal paste at this time.
That's a decent low power-use GPU, and you need it with that PSU.
The parts are compatible. If you put this together, it will run.
It's a decent AMD build. The PSU limits future growth.
There are a lot of efficiency changes I would make, starting with the case and PSU.
Same system cheaper and better. Case includes two fans.
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor ($76.98 @ Newegg)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard ($65.98...
Hi.
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard ($65.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($43.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($47.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 750 Ti 2GB WINDFORCE Video Card ($109.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case ($40.00 @ NCIX US)
Power Supply: XFX Core Edition 650W 80+ Bronze Certified ATX Power Supply ($50.98 @ Newegg)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($12.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($86.98 @ OutletPC)
Keyboard: Rosewill RK-8300 Wired Gaming Keyboard ($14.99 @ Amazon)
Total: $539.87
Generated by PCPartPicker 2015-08-15 10:14 EDT-0400
Better, more upgradable and with WiFi/Bluetooth, but more expensive.
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor ($112.99 @ SuperBiiz)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard ($72.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case ($43.99 @ SuperBiiz)
Total: $597.87
Generated by PCPartPicker 2015-08-15 10:19 EDT-0400
As above but to budget.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($64.00 @ NCIX US)
Total: $548.88
Generated by PCPartPicker 2015-08-15 10:21 EDT-0400
Thank you so much 😀 means alot to me!
