First High End Build....Please Help..!!!
waatanideasirji
38
Hello Everybody,
I am opening a store which is exactly for Internet-Cafe and a Gaming Zone or Club.
I am going to use only one CPU and thinking to add 12 Monitors, 12Keyboard, 12 Mouse and 1 for my use....That means 1 CPU = 13 Monitors, 13 Keyboard and 13 Mouse.
Processor - Intel Core i7-3970X Extreme Edition Sandy Bridge-E 3.5GHz (4.0GHz Turbo) LGA 2011 150W Six-Core
Computer Case - Corsair Vengeance Series C70 Gunmetal Black Steel ATX Mid Tower Computer Case
CD/DVD Drive - LG Black 14X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 12X BD-ROM 4MB Cache SATA BDXL Blu-ray Burner
HDD - (Seagate SV35 Series ST3000VX000 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive) X 2 = 6TB
SSD - Kingston SSDNow V+200 KR-S3080-3H 2.5" 480GB SATA III
Mouse - (Microsoft Optical Mouse 200 for Business White 3 Buttons 1 x Wheel USB Wired 1000 dpi) X 13
Keyboard - (Microsoft Keyboard 200 6JH-00026 White USB Wired Standard Keyboard) X 13
RAM - {Patriot Intel Extreme Master, Limited Edition 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000)} X 2 = 64GB
Monitor - (ASUS VG Series VG23AH Black 23" 5ms HDMI Widescreen 3D LED Monitor 250 cd/m2 ASCR 80,000,000:1, IPS Panel, Height & Swivel Adjustable with Speaker and 3D Glasses) X 13
Motherboard - ASRock X79 Extreme11 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
PSU - Rosewill HERCULES-1600 Continuous 1600W@50 Degrees C ATX12V v2.3 & EPS12V v2.92 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
GPU - (ASUS GTX690-4GD5 GeForce GTX 690 4GB 512-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card) X 4 (Quad-SLI)
CPU Cooler - CORSAIR Hydro Series H100i Water Cooler
UPS - CyberPower OR2200LCDRTXL2U 2190 VA 1650 Watts 8 Outlets UPS
Is this build good enough for my requirements or Please help me to choose parts for my need....
And 1 more question that can I buy 3 X 1200W UPS and use at a same time for cost efficiency and better battery backup or can i use a powerful Inverter with Powerful battery for this ?
Thanks.
@lunyone - All the latest games....Yes all the monitors working simultaneously on single CPU....Is this possible or not ?...1 GTX 690 have 3 Monitor ports that's why i am opting for 4 GTX690 that is equal to 12 Monitors and 1Monitor(Administrator - Me) will run direct from my motherboard.
@pgooch - How 4 X GTX690 = 8 ?
My Motherboard is able to run Quad SLI so Quad means 4 so i am opting to run 4 GTX 690....
A 690 is a dual gpu already. So running two physical 690 would actually give you quad sli. I don't know if what your trying to do is even possible but if it was you would need more vram anyways run 4 7970 toxic better outcome.
How do you plan to connect all those mice and keyboards? Would have to be some kind of large KVM. Edit: KVM wouldn't work - need some kind of huge USB hub maybe?
You'll have to run some type of professional virtual machine software because multiple home users cannot access standard windows OS at the same time.
Can't run more than four GPUs at a time - two 690s or four 680s.
There is resource overhead associated with virtualization that'll put the hurt on the CPU, RAM, and GPUs.
Might cost more but believe you'd be far better served by purchasing 12 less expensive PCs.
