G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi all , i've just built me first pc after putting it off for ages because
of nearves :-( system specs are as follow's
asrock K7S416X Motherboard
AMD Sempron 3000+ Cpu
2 x 512 gentric ram 2700 333
128mg NVIDIA Geforce FX 5200 Graphics card
80gig Gentric Harddrive
Midi Tower with 2 usb 2.0 and mick/headphone/line in & firewire port
sony 16x dvd rom
Ibox 16x Dual layer DVD-RW
Standard Floppy Drive
17" tft Moniter (using dvi port instead of standard port)
O-Tec 480watt 2.1 speakers
wireless keyboard and mouse
windows XP Pro with SP2
I know the pc does me but trying to upgrade some of the hardware but havent
a clue what i should upgrade first. would i get better performace using
kingstom ram then using the gentic ram that i've alrady got? and also i've
been hearing a lot about the slim ie cables the ones what look like yellow
cables do they give better airflow then the normal ide cables that u get
with the motherboard?
i;ve installed all the drivers from the motherboard but the boot up beep
from the onboard speaker is doing my head in , i've been to asrock's website
and there is a bios update to the one i've got what will stop that , but i'm
neavours to flash it because the board is only 6 days old and dont want to
fu*k the machine up , how easy is it to flash the bios and what should i be
carefull of
TIA
sony 16x dvd rom
carefull of
TIA
