Bought the parts from the following pcpartpicker build:
http://pcpartpicker.com/user/jimu/saved/Pb8ypg
the *main* problem im having is that I can't get it to turn on. I've tried checking for loose connections and haven't found any yet, and I got a multimeter to confirm that the power supply is in fact outputting power to the 24-pin connector, although i havent checked every single pin's votage. i also connected my power switch to the power_sw panel on the motherboard.
I have a few sub-questions of parts that I'm confused on that there's not a lot of great documentation on in the part manuals I have:
1. https://lh5.googleusercontent.com/-mRIk_REn_3g/VNenh3-fvdI/AAAAAAAAIRA/s1WxZ49cwIE/w288-h509-no/IMAG0449.jpg
what is this? it comes from the same board that the fan connections come from on my fractcal core 3500. i assume its a power cord, for the fans but i have no idea where i would plug it in. i dont think any cords were included that fit it., except for....:
2. this one.
https://lh4.googleusercontent.com/-swk_aIb5uMk/VNen86dVb_I/AAAAAAAAIRk/qO7U2YOZsDo/w902-h510-no/IMAG0452.jpg
which looks like it should go to my graphics card (zotac geforce gtx 970). there are four of these connections and this one cord has four comparable looking ports. i can just string connect them all and then plug it into my power supply, right? ive tried that and have still had problems getting anything to boot.
sorry if these are dumb questions, but i'm new to this and i honestly cannot find any helpful documentation online with the card, power supply, or case. mostly just trying to get everything to work! maybe these have nothing to do with my 'computer won't turn on' problem.
thanks!
2. this one.
thanks!
