Hi folks, I know that "No Signal" is a fairly common problem, but most solutions I've seen involve getting rid of or updating old drivers, and my computer was literally born yesterday.
I'm using a GTX 1070 (by Zotac, if it matters) in a Gigabyte H170M-DH3, along with an i7-6700 (no K), and a fresh out of the box install of Windows 8.1
I had no trouble when I did my outside-the-case build. BIOS showed up and everything looked fine.
I left the GPU out when I performed the full build and installed Windows, and everything was still fine. Then I powered down, turned off the power supply, inserted the 1070, powered back on, saw all fans and lighting elements working properly...and got "No Signal."
I do get a signal from the mobo port, but only when the GPU is removed.
I haven't tried another PCI slot, but I'm looking for all other possible solutions ahead of time, just in case. 🙁 Thanks in advance!
