I just fired up my first homebuilt PC (from a Soyo barebones kit): the pretty lights came on, it sounded like the drive was spinning up, and then, after no more than five seconds, it simply shut down. No attempt to restart it has been successful. I don't know where to go from here.
I *do* have my suspicions: though Soyo claims this is a 350 watt power supply, the specs checked on the side of the PS run like so:
Rexpower PX-350
Output:
+3.3V@20A
+5V@40A
Max: 200W
+12v@16A
-5V@0.5A
-12V@0.8A
+5Vsb@2.5A
This sounds pretty weak-dick to me.
Is there some sort of reset I should try -- CMOS clear, maybe?
The system:
Soyo K7VME/Athlon 2800XP+ (Barton)/Thermaltake TR2 M2, in Soyo's notorious power-supply-right-on-top-of-cpu-fan case
Ultra PC2700 DDR 333MHz 512MB x 2
Chaintech GeForce FX 5700 / 256MB DDR / AGP 8X
Western Digital Caviar 200GB HD (Default/Cable Select on IDE1) -- is THIS correct? The HD is the only device on IDE1, connected to the last connector on the ribbon.
52X generic CD-ROM drive (Master on IDE2)
Megastor (NEC) Dual Layer DVD Burner combo drive (Slave on IDE2)
Mitsumi FDD/multi-media reader
CPU FSB Jumper (JP3) set to 166MHz (for 333MHz FSB) -- is THIS correct?
And yes, I bought Microsoft Windows XP Home Full Version -- obviously not yet installed...
Help!
Bart Brown
NB -- I have used and modded Macs exclusively since 1991; business circumstances force me to have a PC for my hobby shop. What I know about PC hardware troubleshooting you could fit into a gnat's gnavel.
Rexpower PX-350
Output:
+3.3V@20A
+5V@40A
Max: 200W
+12v@16A
-5V@0.5A
-12V@0.8A
+5Vsb@2.5A
The system:
Help!
Bart Brown
