Hey, I'm going to be builsing my first dedicated gaming pc soon and have some questions. I haven't really examined the gaming pc component scene in a couple of years so its become a whole new world for me (Ram in threes? Thats insane!)
My evetual goal is to have a system that will be able to play Crysis maxed out at 1920x1200 at a constant 60fps. It seems to me that that will mean a Core i7 system with dual GTX 295s. The Core i7 will also help drive my current hobby, World of Wacraft, being so processor-hungry.
Now of course I don't want to dive into that right off the bat. I like spending small amounts to add things over time, and minimize the necessity of replacing components. A rough outline of where I want to start is:
-a good ATX Full Tower (easier to work in with my inexperience, and I assume more easily cooled)
-Asus P6T mobo
-Intel Core i7 920 processor (I don't generally see people recommending the higher end i7's)
-6GB (3x2GB) DDR3 1600mhz ram (haven't researched brands yet)
-a single GeForce GTX 295
-1TB 7200rpm hard drive
-DVD-RW drive
-850w power supply (to support upgrades in the future)
My questions are:
1. What would you change in this build? I don't mind spending a little more now if it means that I don't have to replace the component in the near future.
2. When I add a second GTX 295 in SLI, will I need liquid cooling? Will i need it with a single card and an i&, for that matter? Having never built my own rig I'm kind of scared of doing it. I will be using the built-in overclokcing of the processor and don't know yet if it will be worthwhile to overclock the gpu(s)
3. Will I need something higher than an 850w power supply?
4. These "dual gpu in one card" things are a bit alien to me. is there a concern for the space between the cards when looking at mobo's and their PCIE slots?
5. If i decide later to upgrade to a better i7 processor, what does that upgrade entail? Do you just pop in the new processor and boot it up?
6. Does anyone have any suggestions for more specific selections for the list above? A specific model of the GTX 295? Specific brand of memory? A better mobo than the Asus P6T? Power supply? A case with built-in water cooling?
Thanks in advance.
-Asus P6T mobo
-DVD-RW drive
My questions are:
Thanks in advance.
