first mini itx gaming build review
floors10
18
can you check the components of this build and give suggestions and opinions on the gaming rig. should i make it and what improvements i need to make.
http://pcpartpicker.com/user/daylin_10/saved/TcbwrH
could you give your build for 750$ if this gaming build is insufficient. will there be bottlenecking in this build. will this build be enough to play BF4, DayZ and other new releases in 1080p high settings. i want 1 stick of 8gb ram so that i can upgrade later. i didnt include windows because already have.
thank you
id change the ( 1 x 8gb of ram ) to 2 x 4gb, and id also look into changing your psu. that corsair one you have picked isnt very good, also it says on the nvidia website that the 760 direct cuii needs a minimum of 500watts, i only know this as i have the same card.
apart from that id say its not a bad build.
my graphics card lets me play bf4 at around 55fps on high/ultra settings and thats with a 8-core amd cpu. so i believe yours should be ok.
