You'd definitely want faster RAM (3000MHz ideally) operating in dual channel (so either 2x4GB or 2x8GB), but otherwise, the build is solid enough.
I'd suggest scaling back the cost of certain components (case, a little off the PSU, motherboard etc) to achieve better performance - if budget is a sizeable concern.
For example:
PCPartPicker part list /
Price breakdown by merchant
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($197.88 @ OutletPC)
Motherboard: ASRock - AB350M-HDV Micro ATX AM4 Motherboard ($64.99 @ Amazon)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory ($69.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.38 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1050 Ti 4GB Video Card ($145.99 @ SuperBiiz)
Case: Thermaltake - Core V21 MicroATX Mini Tower Case ($34.99 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($39.99 @ Amazon)
Monitor: Asus - VX238H 23.0" 1920x1080 Monitor ($139.99 @ Amazon)
Keyboard: Cooler Master - Devastator II Wired Gaming Keyboard w/Optical Mouse ($25.49 @ OutletPC)
Headphones: Sades - SA-708 Headset ($22.99 @ Amazon)
Total: $790.68
Generated by PCPartPicker 2017-07-28 17:56 EDT-0400
Slightly better performance (dual to fast RAM in dual channel), for $100+ less.
That money saved could then be put towards either a better GPU (6GB 1060 minimum), an SSD for all around speed improvements, an aftermarket CPU cooler for better OCing,...... or just kept in your pocket for another day.
