Ok this is my first OC. Trying to get my Q6600 SLACR to 3.0 Using this to cool it Scythe SCKTN-2000 100mm Sleeve "Katana 2" CPU Cooler - Retail
My motherboard is ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
So I overclocked it to 3.0 and then ran Prime95 for 8 hours while I slept. When I woke up I was pleased to see that it had no errors but when I checked the cpu temp with the ASUS AI Suite that came with the motherboard the CPU temp was 89-90C. That seems very high so i stopped the test and restarted. When I checked the temp again it was 50c which seems high for doing nothing. Was this just still hot because of Prime95? I had to go to work then so do not know if it would have continued to drop in temp.
Is the cooler I have a decent one? Is the program I used to check CPU an accurate one? any tips or suggestions would be greatly appreciated. Thank you.
