[SOLVED] First PC Build $1200 USD build
Jan 10, 2020
14
I need some input on a rig I'm building, so far I've made a list on pcpartpicker which I have linked below.
https://pcpartpicker.com/list/2XjVBZ
My absolute max price for the build is a round 1200 USD and I'd prefer to have an AMD cpu in the rig. However I'm open to any build suggestions that you guys can give me. This is my first time building a pc so I would greatly appreciate any pointers or tips. Another thing I'd like to mention is that I plan on using this as a streaming rig to stream.
Here is the list:
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($322.99 @ SuperBiiz)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard ($174.99 @ Best Buy)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($68.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive ($104.99 @ Newegg)
Video Card: Asus Radeon RX 5700 XT 8 GB TUF Gaming X3 OC Video Card ($369.99 @ Newegg)
Case: Corsair Carbide Series 275R ATX Mid Tower Case ($59.98 @ Newegg)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($103.97 @ Newegg)
Total: $1205.90
Generated by PCPartPicker 2020-01-11 01:19 EST-0500
Better performance for same price.
All high quality components.
bioax
Upstanding
Nov 30, 2019
262
41
240
14
Everything looks pretty good, except your board doesn't have onboard wifi I believe. You would either need a wifi adapter of some sort in order to access internet. They cost around $10-$15.
Reactions: josiahchan757
Here is the list:
Total: $1205.90
thomas4204
302
20
695
Everything looks great except for the motherboard and WiFi. This ASRock looks like it don’t have any onboard WiFi so you would need to get either a pcie WiFi card or usb to use WiFi with this. Second the Intel 660p 1TB in $20 cheaper and has better read and right speeds. Plus your get nvme m.2 features so it just mounts directly to the motherboard with no cables
Jan 10, 2020
14
I've got a spare usb wifi adapter laying around so I've got the wifi covered. Thank you for the ssd suggestion too, I would much prefer less cables in my case.
Jan 10, 2020
14
Thank you for pointing that out, I wasn't sure if it had wifi capabilities or not.
Jan 10, 2020
14
Here is the list:
Total: $1205.90
Wow, this looks like a pretty solid build for just $1200, I'll definitely look into considering this. Thank you for your response!
