Budget Range: Would like to be under 2k but looking like 3k
System Usage from Most to Least Important: Gaming Overwatch and PUBG without lagging or frame drops, Watching movie streams, Internet surfing
Are you buying a monitor: Yes but not included in this budget, pricing is for only tower
Parts to Upgrade:Thermaltake View 71 RGB 4-Sided Tempered Glass Vertical GPU Modular E-ATX Gaming Full Tower Computer Case with 3 RGB LED
GIGABYTE GeForce GTX 1080 DirectX 12 GV-N1080D5X-8GD 8GB 256-Bit GDDR5X PCI Express 3.0 x16 SLI Support ATX Video Card
GIGABYTE AORUS GeForce GTX 1080 Ti DirectX 12 GV-N108TAORUS-11GD 11GB 352-Bit GDDR5X PCI Express 3.0 x16 SLI Support ATX
CORSAIR HX1000 Series CP-9020139-NA 1000W ATX12V v2.4 / EPS12V 2.92 80 PLUS PLATINUM Certified Full Modular Power Supply
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel Z170 Platform Memory Kit Model 2x for a total of 32GB
ASRock Z270 KILLER SLI/AC LGA 1151 Intel Z270 HDMI SATA 6Gb/s USB 3.1 ATX Motherboards - Intel
Intel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz LGA 1151 91W BX80677I77700K Desktop Processor
Dynatron K17 92mm 2 Ball CPU Cooler for Intel LGA Socket 1151 / 1150 / 1155 / 1156
TOSHIBA X300 5TB Desktop Hard Drive 7200 RPM 128MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
SAMSUNG 960 EVO M.2 250GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E250BW
Do you need to buy OS: Yes Windows 10 64 bit
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: I'm down for whatever but have been using New Egg for reviews, and pricing
Location: City, State/Region, Country - Winston-Salem, NC USA
Parts Preferences: NONE
Overclocking: Maybe, I've planned for it with the higher ram but if it isnt needed the i can step it down.
SLI or Crossfire: Yes , not now unless needed. I have future planning for duel cards later on when 4k gaming become more common
Your Monitor Resolution: not sure will depend on graphics card. don't plan on buying a 4k monitor when a 1080 120hz will cover my needs. i can use that money else where.
Additional Comments: i have two graphics cards on there because one looks to have slightly better specs while the other has 3 hdmi ports. I am not a heavily gamer like a YouTube streamer. i just dont want to build a PC that i could have spent a few more dollars on or in a different place and have not had lag or frame issues.
And Most Importantly, Why Are You Upgrading: Because I currently have a laptop and want to build something worth gaming on!!!
