This is my first pc build I would greatly appreciate it if the community could give me some advice/correction on my build.
Thank you.
CPU: i5-8400
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117824
Motherboard: GIGABYTE B360 HD3
https://www.newegg.com/Product/Product.aspx?Item=N82E16813145063
Case: EVGA DG-73
https://www.newegg.com/Product/Product.aspx?Item=N82E16811205031
GPU: GIGABYTE GeForce GTX 1070 Ti
https://www.newegg.com/Product/Product.aspx?Item=N82E16814932012
PSU: CORSAIR VS Series, VS650, 650 Watt (650W), Active PFC, 80 PLUS White
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139228
SSD: HP S700 2.5" 500GB SATA III
https://www.newegg.com/Product/Product.aspx?Item=9SIA2W07E02012
HDD: WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM
https://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
RAM: G.SKILL Ripjaws 4 Series 16GB (2 x 8GB)
https://www.newegg.com/Product/Product.aspx?Item=N82E16820231875
3rd case fan: Cooler Master Sleeve Bearing 140mm
https://www.newegg.com/Product/Product.aspx?Item=9SIA85V36A0189
Thank you.
CPU: i5-8400
Case: EVGA DG-73
