First PC Build Compatibility Check
Jpch13f
Commendable
Jan 30, 2017
6
Hi everybody. I am planning on Building a PC by the end of February. I am very new to this, but have been doing quite a bit of research in the last few months. What I would like to know is if the parts Ive chosen are compatible?
Case: Bitfenix Commrade Black
MOBO: B150 Gaming M3 (MSI)
CPU: Intel Core i7 6700
GPU: GTX 1070 Armor (MSI)
RAM: Hyperx Fury 16gig (2x8 DIMM's)
PSU:Antec Neo Eco 650W ATX Modular
Cooler: Hyper 212 LED
SSD: Samsung evo 750 250gig
HDD: Seagate Barracuda 3TB 7200rpm
OS: Windows 10 Home
I have used PC part picker and it says its compatible, but I'm very unsure mainly on the Cooler and GPU fitting in the case. I don't quite care much about the looks of the thing compared to its performance btw.
Thanks a lot guys :)
looks compatible at a glance. i've never personally heard of an instance where pcpartpicker's compatibility was incorrect. that case also has plenty of room. i doubt a 212 evo wouldnt fit.
looks good, you dont need 650w though
try to get a good 520w unit
also no point in getting a 6700 setup when you can get a 7700 build since you are buying new
the 212 is ok, but obsolete if you can get a cryorig h7
PCPartPicker part list: https://pcpartpicker.com/list/nTvBxY
Price breakdown by merchant: https://pcpartpicker.com/list/nTvBxY/by_merchant/
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor ($309.69 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.88 @ OutletPC)
Motherboard: Gigabyte GA-B250M-DS3H Micro ATX LGA1151 Motherboard ($73.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory ($89.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive ($72.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.33 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card ($379.99 @ Jet)
Case: Thermaltake Versa H25 ATX Mid Tower Case ($37.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($47.89 @ B&H)
Total: $1096.73
Generated by PCPartPicker 2017-01-30 01:11 EST-0500
