First PC build, do these parts fit together?
dontfeed
28
Hello, this is my first build, do these parts fit together and is the PSU good enough? Please respond fast. Thanks in advance.
PowerColor Radeon HD 7770 1GB GDDR5
PCI-Express 3.0, DL-DVI-I, native-HDMI, DisplayPort
MSI B75MA-P45, Socket-1155
m-ATX, B75, DDR3, 1xG3-PCIe-x16, SATA 6Gb/s, USB 3.0, VGA, DVI, UEFI
Intel® Core i3-3220 Processor
Socket-LGA1155, Dual Core, 3.3GHz, 3MB, 55W, HD2500, Boxed w/fan
Silver Power SP-SS500 500W PSU
ATX 12V V2.2, 80 Plus, Standard, 1x 6pin+1x 6+2pin PCIe, 6× SATA, 3x Molex
Kingston DDR3 HyperX 1600MHz 8GB
Kit w/2X HyperX 4GB DDR3, CL9-9-9-27, 240pin
Corsair Carbide 200R Midi Tower Svart
Fläktar: 1x 140mm Front, 1x 120mm Bak, ATX, mATX, 2x USB 3.0
no, these parts are a bit wrong
for PSU, find one from XFX/corsair 450-550W
for RAM, that kingston is 1,65v ram. make sure you get 1,5v for intel :) can be corsair/gskill
I am buying from http://www.komplett.se/ . My budget is 4000kr. (the currency on the site)
What about;
Corsair Vengeance DDR3 1600MHz 8GB
1x8GB 9-9-9-24 1,5V 240 pins Quad Channel
XFX ProSeries Core Edition V2 450W PSU
ATX 12V V2.31, 80 Plus Bronze, Standard, 1x 6+2pin PCIe, 6x SATA, 3x Molex
Would these work?
Those would be better, you might want to get 550W just to be on the safe side.
I didn't fully understand what you wrote, but did you mean i should get a z77 motherboard instead? Is this one good?
Gigabyte GA-Z77M-D3H, Socket-1155
m-ATX, Z77, DDR3, 1xG3+1xG2-PCIe-x16, CFX, VGA, DVI, HDMI, UEFI
It didn't say if this one was dual channel, would you know if it is? It's the same price as the previous,
Corsair Vengeance DDR3 1600MHz 8GB CL9
Kit w/2x 4GB XMS3 modules, CL9-9-9-24, 1.5V, Vengeance Heatspreader, 240
I know you said that before but is this one good?
