I am now on the verge of ordering my components and I would just like to check if everything fits/is good enough. Ordering from the UK.
My list:
CPU: AMD FX-8350 (http://www.amazon.co.uk/AMD-FX8350-Edition-Processor-4-2GHz/dp/B009O7YUF6/ref=sr_1_1?ie=UTF8&qid=1408042019&sr=8-1&keywords=8350)
Motherboard: Gigabyte 970A-UD3P (http://www.amazon.co.uk/Gigabyte-970A-UD3P-Motherboard-Gigabit-Ethernet/dp/B00F5R9O46/ref=sr_1_1?ie=UTF8&qid=1408042057&sr=8-1&keywords=ud3p)
Memory: 8gb HyperX Beast (http://www.amazon.co.uk/HyperX-1600-Beast-Desktop-Memory/dp/B00A77202C/ref=sr_1_4?ie=UTF8&qid=1408042215&sr=8-4&keywords=ram)
GPU: Sapphire Radeon R9 270X (http://www.amazon.co.uk/Sapphire-Dual-X-Radeon-GDDR5-Graphics/dp/B00FL8H49Q/ref=sr_1_3?ie=UTF8&qid=1408042307&sr=8-3&keywords=gpu)
HDD: Old 3.5" WD caviar 7200RPM (No link)
Optical Drive: 2 x 5.25 drives
Power Supply: XFX Pro 550w Tier 2 (http://www.amazon.co.uk/XFX-ATX-550-Power-Supply/dp/B004RJ8EKI/ref=sr_1_1?ie=UTF8&qid=1408042524&sr=8-1&keywords=xfx+550w)
Case: Corsair 300r Windowed (http://www.amazon.co.uk/Corsair-Carbide-Series-CC-9011017-WW-Windowed/dp/B008B6ONXA/ref=sr_1_1?ie=UTF8&qid=1408042561&sr=8-1&keywords=corsair+300r)
Please could you tell me if it fits, and if there are any better components out there at a similar price
My list:
