First pc build doesn't work
ionutduma95
Commendable
Dec 19, 2018
7
So I finished building my first pc, everything is plugged correctly, checked 100 with the manual, but still it doesn't turn on, just the front led is lighting up that's all
If you need help, post your spec. or the answer to your issue is, you did something wrong when you build it.
Asrock 980DE3/U3S3 motherboard
AMD fx 6350 CPU
Don't remember the graphics card but still something from amd no external power cable and a 500w power supply
The guy I got te motherboard from said the bios is the latest version, how do I uptade the bios?
